Hello, I have tried to install a Redshift custom build for Solaris and the regular OUT context,
meaning I would like it to work in both contexts.
Houdini/Solaris 19.5.303 plugin for Redshift 3.5.04
Downloadable here: https://redshift.maxon.net/topic/31230/houdini-solaris-plugins-custom-builds [redshift.maxon.net]
Tried it with the houdini.env file, but whenever I open the IPR window, Houdini crashes.
Someone in the comments suggested to use packages instead, but I am not confident modifying the lines myself.
That's what they sent me:
"env":[
{"RS_PLUGIN_VERSION" : "${HOUDINI_VERSION}"},
{"REDSHIFT_COREDATAPATH": "C:/ProgramData/Redshift"},
{"HOUDINI_PATH": "${REDSHIFT_COREDATAPATH}/Plugins/Houdini/${HOUDINI_VERSION}"},
{"PATH": "C:/ProgramData/Redshift/bin"},
{"PXR_PLUGINPATH_NAME" : "${REDSHIFT_COREDATAPATH}/Plugins/Solaris/${RS_PLUGIN_VERSION}"}
Would someone be so kind and explain to me how exactly I need to modify this text for it to work?
I am assuming it doesn't work like this straight away?
Things like: Do I replace {"RS_PLUGIN_VERSION" : "${HOUDINI_VERSION}"} with the exact version, like "Houdini/19.5.303"
Or is the advantage of packages that this is not necessary?
How to use json file to make Redshift custom builds work?
2466 3 2- cheesetroyer
- 45 posts
- Steven Quinones-Colon2
- 22 posts
- mabelzile
- 401 posts
cheesetroyer
"env":[
The only lines you need to modify are REDSHIFT_COREDATAPATH and PATH with the redshift installation path on your machine. Place the above in a .json file under $HOUDINI_USER_PREF_DIR/packages.
Edited by mabelzile - Sept. 8, 2022 08:28:14
- Ed B
- 6 posts
