Houdini splines were inconvenient to edit in Unreal, so I opted to use Unreal's splines, selecting and using them as inputs through the World Outliner.
When importing Unreal Engine splines as a line type, points are generated in the middle.
Additionally, corners are not formed correctly, and deformed points are created.
Applying facet does not create clean rectangles.
Why do these points appear, and is there a way to remove them?
Is there a method to only retrieve the points of Unreal Engine splines?
When importing Unreal Engine splines..
855 4 1- gallerykim
- 29 posts
- m_davis1
- 4 posts
- gallerykim
- 29 posts
- m_davis1
- 4 posts
- gallerykim
- 29 posts
m_davis1
According to the plug-in settings page, if you set the unreal spline resolution to 0 in the plug-in settings, it only sends the control points? Maybe that will work?
Thank you for your response. The resolution value seems meaningless. Instead, the "use legacy input curves" option seems to be working that way.
