Hi!
I'm converting an asset to VDB but some geos have no thickness (non-watertight). I remember seing some node/option to deal with those geos. It would give it thickness in a smart way... Know anything about this?
-Olivier
VDB from Polygons: non-watertight geos?
860 7 3- olivierth
- 1013 posts
- Enivob
- 2568 posts
- CYTE
- 686 posts
Geo seal by momme is a valid option:
https://momme.gumroad.com/l/geoseal?layout=profile [momme.gumroad.com]
CYTE
CYTE
- edward
- 7760 posts
- edward
- 7760 posts
- lewis_T
- 238 posts
Vdb topology SDF will reconstruct the data, but it will be larger in size.
The trick is to appply a reshape SDF and erode 1-1.5, convert VDB to poly and us negative ISO offset values.
then you can do another VDB from polygons, from a nice watertight piece of geo, this setup of steps will get you
very close to the original source mesh.
- olivierth
- 1013 posts
- jbudsberg
- 92 posts
In production, we get open surfaces from Modeling often. The common practice is to convert the mesh to an unsigned distance field prior to converting to a signed distance field.
I have an example in the Houdini example file https://www.openvdb.org/download/ [www.openvdb.org] Look for /obj/example_levelset/extruded_sdf
Edited by jbudsberg - April 10, 2024 13:02:11
