node info stops working
2842 9 2- evanrudefx
- 225 posts
Does anyone one know what causes this/how to fix it? Has anyone else had this problem? After using houdini for a while, when you middle mouse click a node or click the “i” icon, I get this error instead of the node info. Its happens to me on linux, on windows, and on windows through steam houdini. The only thing I can do is close houdini and re-open it. Wasn't sure if this is a bug and should report or is there something I am missing?
Thanks,
Evan
Evan
- evanrudefx
- 225 posts
- Jake6
- 5 posts
I suggest you check to see if this problem occurs in Houdini Console 'WindowsError: Error 234'.
If this problem arises, then you can refer to this article:
https://stdworkflow.com/278/houdini-error-when-viewing-node-properties-windowserror-error-234-c-users-admin [stdworkflow.com]
Hope you found that helpful
Edited by Jake6 - Aug. 3, 2022 02:21:26
- evanrudefx
- 225 posts
- evanrudefx
- 225 posts
- edward
- 7720 posts
- evanrudefx
- 225 posts
- H-mech
- evanrudefx
- 225 posts
H-mechThanks, that is good to know. Sidefx logged it as a bug, but it still isnt fixed. I will definitely do this for now.
Hello. I had the same problem! There is a solution in my case. Maybe it will help you.
In Houdini settings, on the Network Editor, Nodes, and Trees tab, you need to turn off Node Info Windows Close When Losing Focus if it is enabled.Image Not Found
Thanks,
Evan
Evan
- H-mech
