Since upgrading (and subsequent re-installing) from Houdini Indie 18.5 to 19.0.531 (Windows 10), I cannot start Houdini using the desktop shortcut or double-clicking an hiplc file. I can only open Houdini via the Houdini Launcher.
Instead of opening, I get a pop-up saying:
“This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.”
The Houdini console says:
“ERROR: Couldn't open resource file "resources" (No such file or directory)”
Anyone have any ideas how to fix this? Do I need to install Qt myself somehow?
No Qt platform plugin could be intialized
4425 4 1- ZyborgGames
- 15 posts
- ZyborgGames
- 15 posts
I've got it working, although not sure what fixed it. Here's what I did for anyone interested.
Completely removing Houdini and Houdini Launcher (also deleted folders in Program Files and Documents) then re-installing broke everything. I couldn't even run Houdini from the Launcher anymore.
Removed all trace of Houdini, again. Downloaded the stand-alone package for 19. Installed this and rebooted multiple times, still bust.
Downloaded and installed the stand-alone package for 18.5. Rebooted multiple times, still bust.
Added these to my Path System Variables:
C:\Program Files\Side Effects Software\Houdini 18.5.759\bin
C:\Program Files\Side Effects Software\Houdini 18.5.759\bin\Qt_plugins\platforms
C:\Program Files\Side Effects Software\Houdini 18.5.759\qt
This appeared to fix it. However, I've since deleted those paths (not rebooted since though) and 18.5 and 19 load fine.
I don't have the Houdini Launcher installed on at the moment. I'll keep with this setup for the time being as it's working, but will try to re-install the Launcher at some point in the future.
Nightmare.
* I also re-installed Python (went from 3.8 back to 3.7) and added C:\Python37 etc to my Path System Variables.
Nightmare.
Edited by ZyborgGames - March 8, 2022 06:08:55
- riderideride
- Cicuta
- 55 posts
Hello!
At some point I was running through a similar issue and after a lot of head-scratching I figured out that I had been toying around with my computer user environment variables and Houdini for some plugin work. Following the HDK documentation I created a HFS user environment variable pointing to "C:\Program Files\Side Effects Software\Houdini 19.5.493". That will pop the Qt plugin errors when opening any Houdini version that is not 19.5 (or the one specified).
Make sure you don't have stuff like this in your user/system environment variables, or remember to update them when changing from one version to another. HDK projects are very strict about the versioning.
Hope it helps someone solving this issue.
Cheers!
Cheers!
Edited by Cicuta - Dec. 17, 2023 18:15:39
- pstorm
Cicuta
Hello!
Cheers!
Thank you, I solved the problem thanks to you! My cause was also like this.
