How can i save ramps presets without using the "save preset" button from the gear icon?
i have an hda with lots of parameters and i don't want to create a new preset for every ramp i want to save.
Ideal interface would be a drop down menu and a save button next to my ramp parameter.
Could i export the ramp as a json file in my HIP dir and append to that each time i press save? then load the selected ramp from the drop down menu somehow (menu would be populated by the json file).
i am thinking python module but i am not sure about this
if writing the ramps in an external file is the way to go, how would i do that and then read the data back?
Any tips on the workflow would be much appreciated!
Save ramp presets
2049 9 2- papsphilip
- 385 posts
- papsphilip
- 385 posts
baby step 1
made a dictionary of the ramp parameters
next step is to make a correct json structure (one entry per ramp point holding pos val and interpolation values) and save it to disk
import json node = kwargs['node'] ramp = node.parm('ramp').multiParmInstances() num = node.parm('ramp').multiParmInstancesPerItem() dict = { 'point': [] } for p in ramp: data = {} for i in range(num): if str(i+1) in p.name(): value = p.eval() name = p.name() data[name] = value dict['point'].append(data) print(dict)
- papsphilip
- 385 posts
baby step 2
corrected the json structure
next step is to append different ramp presets to the same json
and the step after that is to load them
import json node = kwargs['node'] ramp = node.parm('ramp').multiParmInstances() num = node.parm('ramp').multiParmInstancesPerItem() dict = { 'point': [] } for i in range(num): data={} for p in ramp: if str(i+1) in p.name(): value = p.eval() name = p.name() data[name] = value dict['point'].append(data) print(dict)
- papsphilip
- 385 posts
baby step 3
append or overwrite options with pop up window
by the way a different approach to constructing the dictionary was given by tamte aka Tomas Slancik
import json import os path = hou.hipFile.path().rsplit('/',1)[0] + '/ramp_presets/' if not os.path.exists(path): os.makedirs(path) node=kwargs['node'] parm = node.parm('ramp') ramp = parm.evalAsRamp() interplookup = [hou.rampBasis.Constant, hou.rampBasis.Linear, hou.rampBasis.CatmullRom, hou.rampBasis.MonotoneCubic, hou.rampBasis.Bezier, hou.rampBasis.BSpline, hou.rampBasis.Hermite] keylist = [] for i,key in enumerate(ramp.keys()): data = { "pos": i, "value": ramp.values()[i], "interp": interplookup.index(ramp.basis()[i])} keylist.append(data) dict = { 'ramp_name': keylist } filepath = path + 'test.json' json_data = json.dumps(dict, indent=4) if os.path.isfile(filepath) and os.path.getsize(filepath)>0: #if file exists and is not zero bytes user = hou.ui.displayMessage('a file already exists',buttons=('Append','Overwrite',)) if user==0: with open(filepath,'a') as f: f.write(json_data) if user==1: os.remove(filepath) with open(filepath,'w') as f: f.write(json_data) else: with open(filepath,'w') as f: f.write(json_data)
Edited by papsphilip - 2021年10月13日 15:24:50
- papsphilip
- 385 posts
- Saman_batham
- papsphilip
- 385 posts
- Jikian
- 131 posts
Saman_batham
can we change ramps using a slider is that possible if we have same no. of points in ramp
Ramp parameters are essentially multiparms - you can reference each point's position/value parameter directly if you read the "index" value. If you have a ramp parameter with a fixed number of points, you can channel-reference each point's Value independently.
- Yader
- 33 posts
papsphilip
after lots of baby steps...
ok i finished the HDA for saving ramp presets and loading them back in.
Thanks a bunch for this, but I get an error message for folder where I have read/write rights:
File "FP::dev::Sop/ramp::1.2/save", line 1, in <module>
File "FP::dev::Sop/ramp::1.2, PythonModule", line 57, in Save
PermissionError: [ErrnoTraceback (most recent call last):
File "
And is it also possible to save RGB ramps?
Thanks in advance!
Edited by Yader - 2022年9月9日 05:21:14
- fr_3D
- 6 posts
Thanks @papsphilip and @tamte for this solution! For an HDA with many parameters I wanted to export all parameters including color and float ramps as well as multiparms, so I extended the script a bit. Now it seems like all standard parameter types are supported. While ramps are detected automatically, for now multiparms need to be manually defined in the script. Does anyone know a way to isolate multiparms in Python?
### Global import json, os # Manually Define Multiparms Here mplist = ['mp_a', 'mp_b', 'mp_c'] # Wrappers for Separating Ramp, Standard and Multiparm Data in the .json File stdgroup = 'standard' rampgroup = 'ramps' mpgroup = 'multiparms' ### Export Parameters def write_params(kwargs): hda = kwargs['node'] params = hda.parmsInFolder(['Parameters']) from sys import platform dir = hda.parm('path').evalAsString() + '/cache/' # Windows and MacOS Handle File Paths Slightly Different if platform == 'darwin': dir = hda.parm('path').evalAsString() + 'cache/' filepath = dir + '_config_' + hda.parm('preset').evalAsString() + '.json' data = {} ramp = {} ramps = {} mp = {} for parm in params: if not parm.isHidden(): # Loop Through Ramp Parameters if parm.isMultiParmParent(): rampname = parm.name() ramp = parm.evalAsRamp() interplookup = [hou.rampBasis.Constant, hou.rampBasis.Linear, hou.rampBasis.CatmullRom, hou.rampBasis.MonotoneCubic, hou.rampBasis.Bezier, hou.rampBasis.BSpline, hou.rampBasis.Hermite] keylist = [] for i,key in enumerate(ramp.keys()): rampdata = { 'posindex': i, 'pos' : key, 'value': ramp.values()[i], 'interp': interplookup.index(ramp.basis()[i])} keylist.append(rampdata) ramp = { rampname: keylist } ramps.update(ramp) # <continue> ends the for loop’s current iteration continue # Write Standard Parameters data[parm.name()] = parm.eval() # Loop Through Multiparms for mpi in mplist: mparam = hda.parm(mpi) mp_inst = { mpi: [] } num = hda.parm(mpi).evalAsInt() instances = hda.parm(mpi).multiParmInstances() for i in range(num): block_data = {} for instance in instances: if instance.name().find(str(i+1)) >=0: name = instance.name() value = instance.eval() block_data[name] = value mp_inst[mpi].append(block_data) mp.update(mp_inst) #print('........\n') # Wrapper for Standard Parameters datas = { stdgroup: data } # Wrapper for Ramp Parameters ramps = { rampgroup: ramps } # Wrapper for Multiparms mps = { mpgroup: mp } # Append Ramp Values to the Final Dictionary datas.update(ramps) # Append the Mltiparm Values to the Final Dictionary datas.update(mps) if not os.path.exists(dir): os.makedirs(dir) with open(filepath, 'w') as outfile: json.dump(datas, outfile, indent=4) print('Parameters exported to:', filepath) ### Import Parameters def read_params(kwargs): hda = kwargs['node'] params = hda.parmsInFolder(['Parameters']) from sys import platform dir = hda.parm('path').evalAsString() + '/cache/' if platform == 'darwin': dir = hda.parm('path').evalAsString() + 'cache/' filepath = dir + '_config_' + hda.parm('preset').evalAsString() + '.json' if len(filepath) > 0 and os.path.isfile(filepath): # Read JSON for Standard Parameters with open(filepath, 'r') as outfile: parameters = json.load(outfile)[stdgroup] # Read JSON for Ramp Parameters with open(filepath, 'r') as outfile: rparameters = json.load(outfile)[rampgroup] # Read JSON for Multiparms with open(filepath, 'r') as outfile: mparameters = json.load(outfile)[mpgroup] # Set Standard Parameters for parm_name, value in parameters.items(): parm = hda.parm(parm_name) if parm is not None: parm.set(value) # Set Ramp Parameters # Outer Loop Runs Over Every Ramp Parameter Name for parm_name, value in rparameters.items(): parm = hda.parm(parm_name) if parm is not None: keys = [] values = [] bases = [] interplookup = [hou.rampBasis.Constant, hou.rampBasis.Linear, hou.rampBasis.CatmullRom, hou.rampBasis.MonotoneCubic, hou.rampBasis.Bezier, hou.rampBasis.BSpline, hou.rampBasis.Hermite] # Inner Loop - We Query the Current Ramp Name With <[parm_name]> for i in rparameters[parm_name]: keys.append(i['pos']) values.append(i['value']) bases.append(interplookup[i['interp']]) # Initialize New Ramp ramp = hou.Ramp(bases, keys, values) # Set Ramp Parameters parm.set(ramp) # Set Multiparms # Outer Loop Runs Over Every Multiparm Name for parm_name, value in mparameters.items(): parm = hda.parm(parm_name) parm.set(0) if len(mparameters) > 0: blocks = mparameters[parm_name] for i in range(len(blocks)): parm.insertMultiParmInstance(i) for name, value in blocks[i].items(): hda.parm(name).set(value) print('Parameters imported from:', filepath) else: hou.ui.displayMessage('Couldnt find the file!!')
