I have a rop otl in which id like to piggyback
the rendering of some other rops. Basically,
the rop has a multiparm of oppaths to other
rops in the scene which id like to overlay
some settings driven by the parent rop.
I started setting up takes from the PythonModule.
I can create a new take, include parms in the take,
and enable autotake mode, using the relevant
hscript commands via hou.hscript(). However,
when i subsequently try and modify the parms
for the overlay, (via hou.parm().set() or
hou.hscript(opparm)) the render fails, and the
take overrides don't get set. Without the line
that sets the parms the ‘render’ goes through fine.
Is this possible? Can take parameters to nodes
outside of an otl be modified at render time from
an interior shell node in the otls network? will i
have to setup the takes in a parameter callback?
