pekili
Aug. 14, 2010 08:21:32
random movement of density inside fluid container during simulation and strange colors in shaded view,render is ok.
win32sp3,x1600mob
malexander
Aug. 14, 2010 11:04:00
Without a snapshot I'm just guessing, but is it mach-banding that you're seeing? (it would look something like contour lines on a map) These are due to accumulated error when compositing in 8b. If the X1600 supports it, you can try turning on HDR Rendering in the Display options Effects tab.
pekili
Aug. 14, 2010 15:57:37
heres screenshots
pekili
Aug. 21, 2010 03:44:30
this is problem with viewport display of all volume geometry on xp32sp3-x1600mob
pekili
Aug. 30, 2010 06:23:42
I think that sampling division in iso offset conversion(fog ans sdf volume mode)when is not 2^n is making problems in viewport .tnx
malexander
Aug. 30, 2010 13:46:07
It's actually a bug in the ATI legacy driver that isn't converting FP32 data to the internal 8bit RGBA properly. There are a couple of other minor issues, but that's the main one.
pekili
Aug. 31, 2010 01:16:21
any workaround?
pekili
Sept. 1, 2010 08:08:28
in houdini 10 it was ok.
pekili
Sept. 10, 2010 18:19:12
quote:Houdini 11.0.499: Fixed a bug with power-2 3D textures on ATI OpenGL 2 hardware that caused volumes to render strangely (ATI X1000 series, X800/700/300).
not workin on xp32 with x1600
