Search - User list
Full Version: Display point color
Root » Technical Discussion » Display point color
cybermax
how do I display the color of points in the viewport?
So far that I did so, I've created a particle system, where I emit particles on points at first frame and points are colored in viewport
The problem is that if I play, that after few hundreds frame, my 4GB RAM will be full.
So where is problem with particles system or exist other methods like display point color???
tamte
you can easily convert points to particles by appending Add SOP witch checked Add Particle System in Particles Tab
no POPnet needed
cybermax
tamte
no POPnet needed
thank you, I use add SOP every day, but I have never seen particles Tab
The problem solved.
tamte
it was added in Houdini 10.0.240
great feature
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Powered by DjangoBB
