VFXCSN0309
March 20, 2011 11:01:31
hi~ guys
looks like i got a small problem on the edge area.. i want to put noise in colortranfer area by using attribtransfer node.
1. i have used attribtransfer node to transfer color from one object to another(red area)
2.apply attribcreate node to “record” the red area and import as parameter into SHOP network
3 and use multiply to restrict the noise area,
But, my problem is,, by doing this way, i always get a sharp edge,,,,so has anybody got idea how to make the edge soft?????
zarti
March 21, 2011 06:12:49
hi ,
( just trying here )
polygons in this case play the role of pixels in an image . so more polies in the gradient area the more ‘ smooth ’ it wd appear .
also i might suggest you for other similar cases a nice little DA ; Attribute Blur . you can find it on the Exchange page .
here is its link :
http://www.sidefx.com/index.php?option=com_wrapper&Itemid=149 [
sidefx.com]
hope those help !
.cheers
mrCatfish
March 21, 2011 12:10:47
Use the smooth sop to smooth color only. Be careful though, as this sometimes gives you negative values, so you may need to follow up with a point SOP with a clamp expression if this might be troublesome.
