jkim7979
June 11, 2011 10:59:45
Hello all!
I have a basic vop question.
I am trying to set up something like this vop.
y = 0
if (x >10)
y += 1
and y continues to add itself one as frame number increases.
I was able to this with add constant but without the incremental add.
basically y only adds 1 to itself once and it doesn't continue to increase as frame number progresses.
so how can I set this up in vop? Thank you for your help!
tamte
June 11, 2011 11:46:11
you cannot do this in simple VOP SOP since the output is not fed back into the VOP SOP next frame
to do that you need to be in another context like POP or DOP
so in POPs you can increase some attribute with VOP POP and since the particles will have that increased value next frame the VOP POP can again add to it
the same can be done in SOP Solver DOP since geometry can be fed to next frame
jkim7979
June 11, 2011 20:40:23
Thank you so much Tomas!
but im not quite getting what you mean by “increase some attribute with vop pop” in DOP. im using vop sop and tried to use sop solver but obviously i did something wrong because it's not working. could you please take a look at my scene file and tell me what i need to fix? thanks again!!
tamte
June 11, 2011 21:37:43
here is SOP Solver solution
tamte
June 11, 2011 21:43:19
and here is POP solution just for comparison, please look at SOP Solver first as it is commented
jkim7979
June 11, 2011 23:31:08
thank you so much for your help! it is exactly what i was looking for. thanks again!
jkim7979
June 12, 2011 20:46:44
Hi Tomas,
Im sorry to bug you again, but I have one last question. Im trying to pass point data from vopsop to voppop in popnet using your popnet file, but the data doesn't seem to go through the popnet node or even get updated. could you please tell me the way to pass point data from vopsop to popnet voppop?
Thank you so much!
tamte
June 13, 2011 06:38:41
$TEST01 variable is only for accessing per point values of test01 variable
and only on nodes which accept custom variables like point SOP
using it in custom parameter returns 0
parameter X is just single value and it doesn't support per point custom variables so therefore it does nothing
you can create your test01 attribute in VOP POP prior to current VOP POP so it will create per point attribute each frame which will be used for test in second VOP POP (of course it can be all done in single VOP POP)
example: vop_data_to_pop_mod1.hipnc
but if you have per point x attribute (or test01 as you call it now) and you really want to pass that value to pops for testing then you need to recreate that attribute in POPs and feed the values each frame by point() expression
because if you just let particles inherit x attribute at birth it will not be updated as your input attribute changes
example: vop_data_to_pop_mod2.hipnc
jkim7979
June 13, 2011 17:10:49
wow! I can't thank you enough! Thank you so so much!
