bluciensky
Oct. 31, 2011 16:47:13
I am trying to install the plug in … and it didn't work.
I wonder if that is because of the version i am trying to install..
I downloaded
hotbin_osx_H11.0.775 which is supposed to be latest version ?
and my houdini version is H11.0.834..
and it didn't seem like working…
(when i tried opening the example file, it says i don't have ‘ocean’ node, and I don't)
how do I fix this problem..?
matsbtegner
Oct. 31, 2011 17:55:24
Download the source (hotsrc_1.0rc9.zip) and compile it. Instructions are here:
http://anusf.anu.edu.au/~drw900/houdini/ocean/docs/ [anusf.anu.edu.au]
Note: the HOT binary distribution you install must match your version of Houdini. The VEX dso has a better chance of working across versions, but it’s still not recommended.
You will need to recompile HOT every time you update Houdini.
Erik_JE
Oct. 31, 2011 18:29:14
Or download Houdini 11.0.755
matsbtegner
Nov. 1, 2011 12:38:06
Erik_JE
Or download Houdini 11.0.775
That might be a bit difficult since that build is no longer available on the Download page.
Erik_JE
Nov. 1, 2011 12:45:12
matsbt
I will have to agree with you there.
bluciensky
Nov. 6, 2011 03:30:25
I compiled from the source and it works great
Thank you !
