I'm using Houdini 10, in the process of making a tutorial video. I've got one instance where I'm recording (1280X720 windowed area of the screen). I have another instance open, off to the side where it won't be picked up by the screen recorder, and fairly small, but enough that I can see the network editor to make sure I'm modeling the right thing.
At some point, as I'm modeling in the primary houdini instance, it will crash, usually within 5-10 minutes of it being open. The crash, which does display the little error dialog telling where the hip file is being saved, completely locks up houdini, which is strange because usually once you dismiss the initial error dialog houdini pops up another dialog and then when you close that the program exits.
I've been doing this for a while now, but the crashes only started a couple of days ago. Any ideas on what might cause this? Several weeks ago I upgraded the RAM on my system and video card, but had no issues at all until a couple of days ago. No other graphics programs have been acting weird either. Is there someplace where a log file is written out to?
I'm running H10.0.1131 Apprentice HD, I had the previous production version installed, but thought maybe installing a newer version of 10 might help.
I'm on Windows 7 64 bit, 12 GB RAM, Nvidia Quadro 4000, latest drivers.
