If I have a string parameter that uses a menu script to turn it into a dropdown menu, opmenu -l properly returns the item/label pairs. However, the documented python equivalent/replacement for opmenu (hou.MenuParmTemplate) can't apply here because the hou.Parm.parmTemplate() method returns an object of type hou.StringParmTemplate, not hou.MenuParmTemplate, and the menuItem() and menuLabel() methods return empty tuples as a result.
This makes opmenu quite a bit smarter than the hou.ParmTemplate system since it seems to be able to figure out that such string parms are actually menu parms with items and labels.
Is there any ETA on when the hou.Parm.parmTemplate() method will be smart enough to return a hou.MenuParmTemplate object under these conditions?
