miklem
June 10, 2012 16:00:35
I have a simple scene with box and ball. Ball supposed to fall in to the box. The problem is that the ball doesn`t fall in to the box if I`m using Bullet solver. However, if I switch to the RBD solver, it works fine. What am I doing wrong?
miklem
June 10, 2012 16:35:34
The problem is solved. To make it work necessary to uncheck “polygon as a convex hulls” in box object bullet data tab.
