Anonymous
April 16, 2014 17:04:17
Where I should call this function?
When I create selector inside newSelector() I get PI_SelectorTemplate, so to access this function I need to cast it to MSS_ReusableSelector and then set. But if I set it to false, it doesn't work and my SOP still uses existing selection.
Another place where I can access this function would be constructor, but it also doesn't work if I set it there.
Any help???
Anonymous
April 17, 2014 19:29:47
Still can't figure out this one. Anyone?
malexander
April 17, 2014 20:16:27
What this means, is that when you finish making a selection, the selector should not exit. You can continue to make selections with the selector. I don't think it applies to what you want to do. Maybe try allowQuickSelect(false) instead.
Anonymous
April 17, 2014 20:56:29
Nope, it also doesn't work. What worked is
setAllowUseExistingSelection(false);
Anonymous
April 17, 2014 20:58:42
twod
I don't get this. If selector doesn't exist how can I continue to make selections with it?
malexander
April 17, 2014 21:11:02
I'm just reporting the comment above the method in the header
It does report the selector used by the Select state as an example of this.
Anonymous
April 17, 2014 21:19:01
twod
Anyway, thanks for jumping in.
