Emily Luke
Nov. 27, 2014 18:34:44
Hey all
I'm trying to get some volumes to grow in size according to their age, from newborn small to old large. Is there an expression I can type into the voxel size parameter that will “just work”?
I've used particles to build my volumes, so we can work with particles here.
Emily Luke
Nov. 27, 2014 20:13:31
I've got a mathematical expression that i can apply to my problem, basically fixing it. my only problem is that I can't access the $age variable in the vdb from particle voxel size parm. do you guys know how to transfer local variables so that i can access my particle lifetime?
edward
Nov. 27, 2014 20:18:39
The size of the voxels must be the same for the *entire* volume.
Emily Luke
Nov. 27, 2014 21:16:10
edward
so you're saying its impossible?
edward
Nov. 27, 2014 21:18:38
If you want the size of voxels in the same volume primitive to be different, then yes, that is impossible.
PradeepBarua
Nov. 28, 2014 01:18:30
You can fake this:
Emily Luke
Dec. 5, 2014 17:50:53
edward
i was able to do it using pscale. not impossible.
edward
Dec. 6, 2014 01:24:40
I think you're confusing “voxel size” with “number of voxels corresponding to a particle”.
anon_user_37409885
Dec. 6, 2014 14:03:45
A great way to analysis Vdb is with ‘Vdbvisualizetree’ node. It allows you see the volume structure quantifiably.
