kaidu
Aug. 10, 2015 11:47:58
Hey there
I'm very new with houdini. I tried to fracture a geometry. I went through a tutorial. There it says that i have to create a voronoifracture node and a scatter node for some points on my geometry, but in Houdini 14 i didn't find those nodes if i press tab.
Did i make a mistake or is the reason for the problem the newer version?
Is there any way to solve that?
Thank you!
tricecold
Aug. 10, 2015 16:20:08
they are there, but to see them you need to be inside the node of the object, then hit tab and as you start typing scatter node will appear
Dean_19
Aug. 10, 2015 17:21:06
Are you sure you're in the right context? These are sop (surface operator) nodes, and only accessible in this context.
To make sure you're in sops, put down a geometry object, and jump inside it (by selecting it and hitting enter!).
