olivierth
Jan. 18, 2019 16:46:59
Hi!
I've set my point f@pscale to be set from a chf in a point wrangle. No matter how I play with the slider, nothing happens to my bevel.
-Olivier
Aizatulin
Jan. 20, 2019 04:12:26
have you tried different values for the pscale in the point wrangle (for example multiplicating by @ptnum or something), because your values looks like being all the same and divisions should be >= 2.
tamte
Jan. 20, 2019 12:26:38
make sure your Offset parameter on Poly Bevel is not 0
it acts as a multiplier to the Point Scale attribute values
olivierth
Jan. 21, 2019 17:09:28
AHHHH!!!
The problem was the divisions. I had it set to 1. As soon as I set it to 2, it fixed the problem.
Thanks tamte!
-Olivier
