i create a fuse SOP, then i make 3 duplicates (copy-paste the node).
i modify them so each of these new fuse nodes have its own different parameter setting.
later in other project, i want to keep this setting, so i can load these customized fuse nodes as for example : fuse1,fuse2 etc (each with different setting).
i know i can save this preset in parameter pane which mean i have to load the preset each time i use it, but i wanna go faster…
what i have in mind is creating toolbar macro for every modified fuse node. so i can access them directly and faster from tab menu.
everything is ok in the network pane…
but the big problem is : i cannot access this macro from within 3d viewer , the macro is not available here. is it possible to access the toolbar macro here?
anyone can help,
thanx
