stevester1
Aug. 20, 2006 18:36:59
Hey guys, I recently followed the tornado tutorial on 3dbuzz and I was wonderring if anyone knew how I could render out the points into visible geometry. I tried using a copy sop but it didn't come out good, thanks for the help, sorry if this is an obvious question.
jason_iversen
Aug. 21, 2006 02:50:30
Look in the Render tab of any Object node and you'll see a Geometry parameter set to “Geometry As Is”. Switch this to “Render only points”, and also make sure you have a point attibute called “width” on your geometry which determines the diameter of the rendered points.
This will render points facing the camera - unless you have an “orient” vector attribute on the points.
Hope this helps,
Jason
