mzigaib
Nov. 28, 2019 22:57:36
Does collapsed materials works on LOPs? If I have old collapsed materials and try to copy paste in LOPs it doesn't work only if I create a new one, should I create them again?
mzigaib
Nov. 29, 2019 20:22:59
I figure out what's the problem with the shader, the problem is that my bind ‘Cd’ color is not working inside LOPs which is multiplying the diffuse color, I already used the import SOP to bring the attributes in to LOPs but for some reason I can't use the bind to get the color point what am I missing?
Thanks.
jsmack
Nov. 29, 2019 20:41:43
Use a surfacecolor VOP to get point color. Binding Cd won't work for Lops since Cd is renamed to displayColor to follow the USD spec on import.
mzigaib
Nov. 29, 2019 21:02:33
jsmack
Thanks you very much for the info!
