Hello everyone!
Yesterday i just accidentally came across this effect (call it whatever you want ).
I will provide you with a file, where i show my setup, i used rest position, and used it as a P to wire into a noise (in VOP).
I wired time to offset so i can update and see the effect, when i wire independently the vector inputs from rest to noise, as i divided them with vector to float, to see what will happen if i isolate the vectors going into noise.
So, my question is, how do i go on understanding what is exactly happening? I do understand that after wiring independently (x,y,z of the rest, vectr to float) i get different outcome of the noise, and i can see it behaves per axis, so i wire only x input and i get noise on the x axis…which is fine, i get that. But i want to go a bit deep and understand why does that behave like that in the first place.
edit: i figured its much better to provide a file and see for yourself . Here it is
