String comparison in Hscript
   5038   4   0
So I need to drive a switch sop based on a parameter in another sop, to do so I've written the folliwng code:
    if ( ch("../my_parameter/group1") == "none" )
        return 0;
And this is the error I get:
Error:       Unable to evaluate expression (Bad data type for function or operation (/obj/geo1/HDA_1/switch1/input)).
How can I compare two strings in Hscript?
Edited by SteN - April 15, 2017 16:22:37
https://vimeo.com/user43100796 [vimeo.com]
The
ch()
expression returns a float, not a string. For strings, you need
chs()
(note the s after ch).
edward
The
ch()
chs()
Yea I forgot to mention: it doesnt work even with the chs() function.
Here's an example file.
(Im still working in H15.5)
Edited by SteN - April 15, 2017 17:16:21
Hscript_error_example.hipnc (50.4 KB)
you have to use strcmp()
    if(strcmp(chs("../random_node/geotype"), "poly")==0)
        return 1;
and not sure but the values you are refering here (“none”) or in your file (“primitive”) are not valid for group geotype parm, so it would never switch to one anyway
the valid values are:
'all', ‘bezierc’, ‘bezier’, ‘mesh’, ‘circle’, ‘MetaSQuad’, ‘meta’, ‘nurbc’, ‘nurb’, ‘PackedAgent’, ‘AlembicRef’, ‘PackedDisk’, ‘PackedFragment’, ‘PackedGeometry’, ‘part’, ‘PasteSurf’, ‘poly’, ‘polysoup’, ‘sphere’, ‘tetrahedron’, ‘trifan’, ‘tristrip’, ‘tribez’, ‘tube’, ‘vdb’, ‘volume’
tamte
        return 1;
I didnt know the strcmp() function, now it works.
That chs(“../random_node/geotype”) I just used it as an example, the real channel is referring to an ordered menu wich contains a “none” option in it
