I am trying to change the Position of points using VEX code within Attribute VOP node.
When trying to set @P, I am getting the error "read only expression on left side of assignment, even though @P is not a read only attribute??
I have attached the hip file. Any help is greatly appreciated!!
"Read only expression" error when trying to change @P
2874 2 0- dl2867
- 4 posts
- dl2867
- 4 posts
- 8597 posts
what makes it Read only is that it's not specified for export, so it will not be added to export arguments of the shader
inside of VOP delete geometryvopoutput1 and geometryvopglobal1 as they are already defining P as read only since nothing tries to write to P
and then on snippet1 in Bindings To Export specify P or some pattern that includes all attribs you want to write to like *
