so I know kinefx is set up as 3x3 world transform animations on the points
is there an easy way to to visualize an animation with all the bones animating in local space from world zero?
I see rigdoctor with initialize transforms adds a local 4x4 matrix, but I don't know much about matrix math, so I'm not even sure how I could transfer local to regular transform.
basically looking for a procedural way to spot joints that don't move much in an animation
view kinefx animation as local transforms
1490 4 1- Sirvoxelot
- 75 posts
- 8602 posts
- Sirvoxelot
- 75 posts
- 8602 posts
Sirvoxelot1. you can use cracktransform() VEX to extract transform components from matrix
got any vex that I can copy to transfer '__effective_local_transform' or 'local transform' decomposed t: or r: to P ?
2. however you can also use Attribute Transform Extract SOP to do it without VEX for matrix and matrix3 attributes
3. if you just want to view them in Geometry Spreadsheet, you can also just turn on View/Decomposed Matrices
- Sirvoxelot
- 75 posts
