Hi guys,
Is there a way to design HDAs with a primary input and multiple secondaries inputs like the LOP Graft node to use it as an example ?
Thanks a lot,
Julien
HDA with primary input + secondary inputs
3541 11 7- julien-b
- 66 posts
- efi_ex
- 4 posts
- sidefxbeta
- 7836 posts
- 8621 posts
it would indeed be nice to be able to specify first input to be visualized as a separate connector from the rest
jsmackall nodes have fixed number of inputs AFAIK, for HDAs if maxinputs is a large number they will be visualised as multiinput, the point is to be able to visually exclude the first input and only 2+ to be visualized as multiinput if there is a lot of them
HDA's require a fixed number of inputs. I don't think that will ever change.
Edited by tamte - Sept. 11, 2020 22:52:14
- blented
- 61 posts
Yeah, we'd just need a checkbox under basic that specified “split out first input” or something, then as Tomas said you can get it to “look” like a multi-input by just setting max inputs to like 50+.
Our aim is to put an expression in the graft node to control the numbering of duplicates, with additional options to “group” incoming prims. None of that really works though if you can't split out the first input.
Grant Miller
VFX Supervisor
Ingenuity Studios
VFX Supervisor
Ingenuity Studios
- Andr
- 900 posts
- 8621 posts
Andrwouldn't the functionality be achieveable curretly though?
since in theory it wouldn't change anything, just visually the first input would be shown separately and also omitted from the UI list for reordering
but internally it wouldn't make a difference so should not cause technical issues other than visual and UX confusion
Edited by tamte - Sept. 12, 2020 21:24:24
- blented
- 61 posts
Yeah the UI / UX of it isn't great w/out the first input separated. We've been treating that as our “B” pipe from a Nuke comp sense and it's been working well for assembling larger scenes. Without it separated it's a pain to connect a different input to #1, you also can't have it be empty and just use it as a “group” node which graft currently lets you do.
Grant Miller
VFX Supervisor
Ingenuity Studios
VFX Supervisor
Ingenuity Studios
- 8621 posts
Grant Millercertainly makes those tasks more difficult, even though technically both are achievable, but definitely not convenient
if you are submitting RFE, I thik it'd be good to ask for a slider for number of separate inouts, cause I can definitely imagine scenario with first 2 inputs separate and rest multiinput, or first 3
Edited by tamte - Sept. 12, 2020 21:51:42
- aaronauty
- 39 posts
- Ben Toogood Aardman
- 53 posts
