Python event for node selection / flag toggle?
455 4 0- raincole
- 448 posts
- alexwheezy
- 209 posts
This can be done with addEventCallback by specifying the appropriate hou.nodeEventType. But this callback will only work with a specific node type not with any.
https://www.sidefx.com/docs/houdini/hom/hou/OpNode.html#addEventCallback [www.sidefx.com]
- rafaels
- 696 posts
Yeah, I was doing something similar, you just have to make sure you use the most appropriate event handler:
def your_function(node, event_type, **kwargs): print(kwargs) # just to check function is being called hou.ui.displayMessage(f"Node {node.name()} has been changed.") your_node.addEventCallback((hou.nodeEventType.AppearanceChanged, hou.nodeEventType.FlagChanged), your_function)
Edited by rafaels - March 6, 2024 08:48:16
Toronto - ON
- raincole
- 448 posts
rafaels
Yeah, I was doing something similar, you just have to make sure you use the most appropriate event handler:def your_function(node, event_type, **kwargs): print(kwargs) # just to check function is being called hou.ui.displayMessage(f"Node {node.name()} has been changed.") your_node.addEventCallback((hou.nodeEventType.AppearanceChanged, hou.nodeEventType.FlagChanged), your_function)
alexwheezy
Thanks for your answers. However, if I understand it correctly, this will just register the listener for a specific node. I'd like to register something "global", in other words, I'd like to call certain function when the user selects any node.
What I'm trying to make is a "history" panel, where the user can see a list of nodes that they selected, and jump to any one them, similar to a browser's history list.
Is it possible?
- alexwheezy
- 209 posts
You then have to dig deeper into the network's event handlers.
https://www.sidefx.com/docs/houdini/hom/network.html#intercepting-events-globally [www.sidefx.com]
https://www.sidefx.com/docs/houdini/hom/network.html [www.sidefx.com]
