Hi
I have an object with different groups inside Houdini and I would like to export these groups as selection groups or materials. I tried exporting via File Sop but it exported neither materials nor groups as sets.
Any suggestions?
thanks
Exporting .obj with groups?
5587 5 1- kursad
- 88 posts
- probbins
- 1145 posts
- kursad
- 88 posts
- kursad
- 88 posts
Just to follow up on exporting seperate items using foreach idea:
I have managed to export every group as a seperate object using foreach sop. I have put partition and connectivity sops between my groups and foreach . I used attribute in foreach panel,which then I was able to use stamping inside the file write node inside the foreach sop. So far it does the job for me. At least every group is exported with unique name, stamped with the connectivity output.
Ideally I would like to export my objects with their proper group names. What would be the way to achieve that?
- 8635 posts
no need for connectivity/partition if you already have groups
just use foreach in group mode with groupmask *
then use stamps() inside to stamp your for variable
it will contain the name of the current group (notice stamps(), not stamp(), because the variable contains string (group name))
i am not in front of houdini right now, but it should work that way
- kursad
- 88 posts
