Hi everyone, I think this is a common question but I flipped through the forums and found no direct answer. I exported a geometry to .obj in H8 a long time ago. Since H9 has a new GUI I was wondering how it's done in H9.
exporting to .obj using H9
7021 11 1- SPEED^_^
- 7 posts
- circusmonkey
- 2624 posts
- SPEED^_^
- 7 posts
- symek
- 1390 posts
Use a ROP output driver , listed under managers and of course use the files extension .obj
Perhaps shortcut for exporting *.obj under RMB of any SOP is still valid…?
Does this export normals or texture coordinates or material info?
No martial info I'm afraid. UV and N if they exists on geometry.
(UV as vertex attribute and UV as point attribute are interpreted slightly differently as I suspect but I've never investigated what is precise distinction.
Nevertheless OBJ supports two ways of defining UV and this is somehow related issue. Maybe some one can write something more.)
cheers,
sy.
- jason_iversen
- 12545 posts
SPEED^_^
Got it thanks. Does this export normals or texture coordinates or material info? or does it require further operations?
http://odforce.net/wiki/index.php/Obj [odforce.net]
- SPEED^_^
- 7 posts
- jason_iversen
- 12545 posts
Add a Point SOP and “Add Normals” to get the normal attribute to be calculated (else it just uses the implicit face normal dictated by the vertex order).
- danmeyer
- 42 posts
- jason_iversen
- 12545 posts
Like with all filenames, it recognizes the extension.
- danmeyer
- 42 posts
- jason_iversen
- 12545 posts
Here is an unofficial list:
http://odforce.net/wiki/index.php/FileFormats [odforce.net]
And you can also type “iconvert” on the command line for a complete list of image formats.
- stevenong
- 1632 posts
The help docs have the information too.
http://localhost:48626/ref/formats/geometry_formats [localhost]
Cheers!
steven
Cheers!
steven
