every time i have to manually start it by /usr/lib/sesi/ ./sesinetd.startup start, any good advice if i want to let it automatic start up with the system start up?
thanks!
How To auto start the houdini 9.1 server in opensue 10.3 64?
2632 2 0- thomaswang
- 8 posts
- Pagefan
- 519 posts
if i am not mistaken, the license script puts a file (the startup script) in /etc/init.d called sesinetd (or maybe it is the sesinetd.startup). If not, then it should be in the /usr/lib/sesi directory and you have to copy it over to /etc/init.d. Then all you have to do is either manually make a symbolic link in the runlevel-directory where the server should start or you can use Yast to set it.
- thomaswang
- 8 posts
