Can someone please run me through this. I've done this in H8 but H9 is different. I don't want to instance the geo just the shaders onto the geo which have been copied onto points.
Thanks,
Bob
Shader instancing in H9
3389 4 1- bobster
- 88 posts
- edward
- 7773 posts
- bobster
- 88 posts
Well that's for instancing geometry. I want to instance textures. The way I did it in H8 doesn't seem to work in H9. Also, my memory must really be bad ‘cause I know I’ve done this before but I randomize when the animating texture starts based on rand $PT or $ID but neither of those work in the shop or cop file read, so how can I do this?
- bobster
- 88 posts
- mark
- 2603 posts
bobster
If I remember correctly in H8 I created a string attribute vm_surface and placed the image file with expression in back ticks and this worked but I've tried that in H9 with shop_vm_surface opdef: op: and nothing works.
Please help.
There are several ways to do this. One is using the new material overrides. See the attached.
Another way would be to create a string attribute which matches the parameter name of the texture.
