BUG: strange string bug
   3538   2   1
hi!
I just bumped into this yesterday, when my 1 Mb hip file suddenly grow to 135 Mb.
It's build 10.0.300. winxp32 vc8
So every time i save my file, it will write into file bunch of “\”\\\“\\\”\“” signs.
Where these come from?
I found it. It is in the color settings LUT string input field.
Every time I save, this field gets populated with more and more “\”\\\“\\\”\“” signs. It leads that a couple of Kb file will grow to 100 Mb.
Also it writes this into color.prefs file where it says
ui.cc.lut.val := “\”\\\“\\\”\“”;
I wiped my prefs folder to start fresh, and just put down a grid in a new file, saved it, restart houdini, open the file and You can see the new “\”\\\“\\\”\“” signs there already.
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
Definitely a bug.
This should be fixed in build 10.0.314
Side Effects Technical Support
