possible to interactive update pyqt4 gui?
   7353   3   0
Hi all! I want to make interactive update pyqt4 gui, so that the gui (in my exemple - checkbox button) will interactive update when i changed node parameter in houdini (node null - display parameter) or drag time slider. It is this possible?
put pyqt_houdini.py from $HFS/houdini/help/hom/cookbook/pyqt/part1 to $HOME/houdini10.0/scripts/python
gui.tar.gz (28.6 KB)
hi again. how to do interactive update pyqt4 gui?
be or not to be “real time” gui?
In your code you check the value of the slider when MainWindow is initialized, but there has to be some kind of refresh during the event loop. You could go about that in different ways. Here's an example using a timer that will refresh the checkbox once per event loop cycle.
best,
Michael
gui_refresh.tar.gz (28.8 KB)
you're the best. excellent response
