Creating a Simple Screw
   47041   22   2
old_school
ok here's my attempt at a screw. Lag bolt more like it. I like the profile approach as opposed to the old school make-a-corkscrew-then-pound-the-crap-out-of-it way.
Hopefully the cookie (boolean) operations hold up…
I am sure that there are procedural ways to better fuse up the shaft to the thread and better work on the tip. It's just lining up your ducks.
As well I eyeballed the copy SOP to align the sweep of the profiles but I am sure you can get simple math in there to do real thread pitch standards.
Is there a H18 way ? I kill a half day for tutorial searching and self trying..
I only want thread for the screw. The newest tutorial i found, was from 2016 i think and the points node is now another node.
Greetings,
peronal: great Software came from Maya…
Here is the most Houdini way to do a screw..
screw.hipnc (106.1 KB)
you can also just use group-range then exploit the divide sop to clean it up.
meanwhile on shadertoy…
https://www.shadertoy.com/view/XtffzX [www.shadertoy.com]
screw.hiplc (159.1 KB)
