Hello, I'm having big trouble solving this. First I use shatter on a model and then I want to export each piece to a sequence of files, but I get only one .bgeo file (or .obj), despite using a stamp function in the name of the file for the current variable.
The reason I'm doing this is to clean up the mesh that shatter produces. I'm getting some really, really weird shapes, much like stripes, running along the cuts. If anyone knows a better way of fracturing an object that directly using shatter, please let me know.
Not sure if you have the same issue I had recently with similar pipeline. Instead of “stamp” expression try the “stamps” expression. It spits out a string variable.
Problem solved, I was actually using ‘' instead of `` in the expression, silly me. Anyway, this exporting to obj sequence didn’t do any good but it was a good try.
