Hi
I am trying to render particles with instances and sprites. According to the docs it is very easy to setup. However I have created a simulation and cached my particles to disk, so I am not dealing with the Popnets at all and all the solutions inside the documentation deals with the solutions that are added within a popnet sop like instance and sprite operators inside the popnets.
Any suggestions?
thanks
Point instances-sprites after caching particles to disk?
3160 2 2- kursad
- 88 posts
- lloydwood
- 105 posts
I'd quite like to know the answer to this as well.
I've got a load of particles saved to disk and then loaded at render time with a “mantra: delayed load procedural” but they render as spheres or points if you turn “render as points” on. I want them to render as sprites though.
Is it even possible to have delayed load particles rendered as sprites?
Can anyone shed some light on this?
- pclaes
- 257 posts
This might help you a bit:
http://forums.odforce.net/index.php?/topic/11282-possible-sprite-with-delay-load [forums.odforce.net]
