Crash hkey.exe
18126 14 2- deel77
- 2 posts
- john_z
- 45 posts
Same problem also running other exe.
Houdini 11.0.446.7, Windows 7 64bit
Apprentice license, licensingMode = localValidator
Here's the crash log (hmaster.exe):
Crash report from john; Unknown App Version 11.0.446.7
Traceback from Wed Jul 28 11:34:23 2010
Caught signal 11
+0x77a11da0
+0x777c2c7a
+0x75176dfb
+0x7028e6bb
+0x73e361ae
+0x73e4399c
+0x73e3ada4
+0x73e3df59
+0x73e3fec1
+0x73e3e546
+0x73e9f401
+0x4000af99
+0x7150b815
+0x7150be0f
+0x4000c02c
+0x777bf56d
+0x779f3281
Caught signal 11
+0x77a11da0
+0x777c2c7a
+0x75176dfb
+0x7028e6bb
+0x73e361ae
+0x73e4399c
+0x73e3ada4
+0x73e3df59
+0x73e3fec1
+0x73e3e546
+0x73e9f401
+0x4000af99
+0x7150b815
+0x7150be0f
+0x4000c02c
+0x777bf56d
+0x779f3281
- houdiniuser42
- 42 posts
- deel77
- 2 posts
- houdiniuser42
- 42 posts
quick side thought: should H11 take over 20 minutes to install on vista64?
i have 10.0.528 working fine on same machine and was able to install H11 on a laptop running Ubuntu 10.04 fine ( and installed very quickly ).
Edit: crash log is attached & via another thread I sent off an RFE.
Edited by - July 30, 2010 00:56:31
- john_z
- 45 posts
I've solved reading this post http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=20267 [sidefx.com].
thanks
go to the properties on the Houdini icon and select the compatibility tab. Select the “Run this program in compatibiltiy mode for:” checkbox. In the pull down list I selected "Windows Vista(Services Pack 2).
thanks
- edward
- 7766 posts
- fredd23
- 12 posts
even after following the above instruction i still get my houdini crashing all the time on win7, even with check box etc..
the instalation has no problem, it is when i use it
am on a laptop HP with a notebook nvidia 1GB gpu
anyone has another idea
Crash report from XXXXXXX; Houdini Master Version 11.0.469
Traceback from Thu Aug 12 12:02:19 2010
Caught signal 11
Caught signal 11
- ragupasta
- 349 posts
Hi guys.
Sorry to revive an old thread, but im getting this problem with my new laptop. This is not a massive problem, as most of the time I can use my desktop.
Houdini installs fine, until I allow it to get apprentice licences, then hkey.exe immediately crashes.
This has happened with the production build (H11.0.581) and the newest daily build (H11.0.643).
I suppose this laptop specs might help.
Sony Viao
Intel i3 @ 240ghz
4GB RAM
Windows 7 64 bit premium.
If you remind me how to get the Houdini error logs, I can post them if you want them.
Cheers
Ragu.
Sony Viao
Intel i3 @ 240ghz
4GB RAM
Cheers
Ragu.
- malexander
- 5170 posts
- ragupasta
- 349 posts
Hi twod.
Thanks man. That worked a treat. Silly thing is the amount of times I've seen peoples problems fixed by setting that variable, I should have known better.
As for the CPU, yeah I'm pretty impressed with it.
My desktop is a i7 980x (12 processors @ 3.3 GHz) and that's a beast for a desktop machine, that's why I went for an i3 series laptop.
Cheers for your help man.
- ScuFF
- 1 posts
That works for me too.
But openGL software mode is much slower. Viewport is litle bit laggy.
U can permanently turn on your nvidia video adapter by setting parametrs in NVIDIA control panel. That works as well, but you still have acceleration on viewports.
By the way after this houdini is refuses to update viewport. Have to manualy interact with it by “camera tool”. Dos anybody know how to fix this?
- malexander
- 5170 posts
- xukca
- 50 posts
Hello, I installed houdini apprentice on my DELL laptop (its from 2011). Everything installs fine, but then the license tool fails to start (hkey.exe crashes on execute), here is the log:
Sad thing is, I can use only my laptop during the week, so not being able to run Houdini is hurting me (and my demoreel) a lot.
Problem signature:
Problem Event Name: APPCRASH
Application Name: hkey.exe
Application Version: 13.0.0.314
Application Timestamp: 51b180c1
Fault Module Name: atio6axx.dll
Fault Module Version: 6.14.10.9902
Fault Module Timestamp: 4c05c596
Exception Code: c0000094
Exception Offset: 0000000000928f0b
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 3e11
Additional Information 2: 3e11f86177420eb70791c110a44a30f2
Additional Information 3: d5b2
Additional Information 4: d5b28af7f9e13400febe87a9172cc331
- chrism
- 2498 posts
Please log a bug for this issue. Thanks!
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=15604 [sidefx.com]
Chris McSpurren
