I am buried deep within a subnet. I would like to get the name of the main transform node on /obj level for the node using hscript. How can I do this?
I am using the origin() expression to get the position of one object relative to my main object, which is why I need to know the name of my transform node. This will be part of an otl, so I can't just type the name of the node in or assume the user might not bury the asset further in subnetworks.
Name of main transform node
2308 3 1- aswaab
- 214 posts
- Soothsayer
- 863 posts
- Soothsayer
- 863 posts
Well, I messed about a bit and perhaps this will help further…
You can get the object's name with the attributeStringEdit node. If you first create a string attribute with value `opfullpath(“.”)` and then use:
to: *
that seems to give you the node's name.
Edit: The following expression will do the same:
pythonexprs(“hou.node('.').creator()”)
to: *
Edited by - Dec. 29, 2010 01:36:19
Jobless
Jobless
- aswaab
- 214 posts
