In my DOP sim, I want to be able to control the angvelx attribute, with some kind of expression, for every object in my fractured RBD.
Something like if(angvelx> 10, 10, $ANGVELX )
How can this be set up inside DOPs?
DOPs modify and attribute eg: angvel
10538 18 0- oblongowl
- 40 posts
- asnowcappedromance
- 512 posts
sorry I don't have Houdini in front of me right now, but what you're looking for is when you hit tab in the network view under “position”, it's either the motion DOP or another one of those nodes. There you should find the angular velocity fields which you can then modify with your expression!
cheers,
Manu
cheers,
Manu
- oblongowl
- 40 posts
Thanks for replying.
I know where the angvelx is located. But I dont know where to put an expression to make a difference, and how the expression should look, in order to accomodate all fractured groups eg: using dopfield() and $OBJ variables. i cannot find a single example where such a variable gets modified.
- 512 posts
ok I attached a sample file for you, it shows how you can clamp the angular velocity with an expression.
Another way to do it would be to use a drag force and let it only affect angular velocity. If you want to know more about it you can have a look on how the rbd auto freeze node accesses angular velocity, just lay down the node in your network, rightclick > allow editing of contents > dive into it and have a look at the node that contains the ang vel data.
cheers!
cheers!
- oblongowl
- 40 posts
Thats a perfect example - thanks for sharing - I just could not find a simple useage of accessing the channels for these values. This opens up a lot of possibilities and answers for me now.
Ive had a lot of success with the Auto Freeze , but not explored its guts … i heard it was not very successful with bullet. Any ideas about that?
Thanks again
Thanks again
- 512 posts
so far I can tell you that Bullet actually switches the rbd objetcs active state from 1 to zero, so on the technical side of things it works. BUT I couldn't actually notice a huge performance jump as soon as objects get frozen, so I think it can be improved a lot. You should browse a little bit on the beta forum to get more information about that …
glad I could help!
glad I could help!
- oblongowl
- 40 posts
- 512 posts
I assume you want to activate objects over time?
here's a hint.
Try to go the SOP Solver route, let every object have a centroid or center of mass and make sure both objects have an attribute on them which keeps them associated. Then you can color those points based on what ever activation you want to achieve (running a sphere through the points for example) and transfer the color attribute within a vopsop from each point back to the points of its original object. Next you make sure every object that has been colored gets an attribute with the value of one and now you can access those attributes in the DOP context to drive your activation.
Let me know if you get stuck
here's a hint.
- oblongowl
- 40 posts
- oblongowl
- 40 posts
Hello again.
So I did get the point to fractured object relationship working,
although im using a point() to simply lookup the attribute value from a point cloud that has same ‘ids’ as the dop fractured object ids.
Not sure exactly why you mention using a sop solver though. Is there a particular reason for the sop solver - the examples of useage are sketchy to say the least, so its not like i can just plug it in and test it haha.
- 512 posts
- oblongowl
- 40 posts
Thanks for that. Thats a good way to bake in attributes.
Any idea if there is a way to actually just bring in one point attribute and sop solve only that.
Taking in all the geometry via sop solver seems a bit heavy handed.
I guess, in some cases a solver could be used in SOPs, but im intrigued if an attribute like ‘Cd’ could be brought into DOPs, solved (as in use a sop solver) and then use modify data dop to add this to existing DOP geometry?
- 512 posts
yes, that's exactly what the SOP solver is designed for, to grab DOP geometry and change it on the fly while it's simulating, a great feature in Houdini, which I use all the time.
As for using the SOP Solver only for one attribute. Hmm never did that but it should work, you could split your tree in SOPs and kill all the attributes but one on the one side, put this into the SOP Solver and then transfer the altered attribute with an attribte transfer SOP or a VOP SOP back to your original geometry. Give it a shot !
Oh and check out the shipped examples, there's some good stuff on the SOP Solver!
- oblongowl
- 40 posts
Oh i meant actually doing that all in Dops. In sops thats easy for me, but Dops syntax and expression is totally alien to me, and very frustrating to learn the simplest things …
For example, to simply pull in a point cloud, and access attributes off that, eg ‘Cd’ point attribute. So lets say i take a point cloud into Dops via the sop geo (ior sop solver) and merge it in with my stream, as a new Dop object: what command would you use to access the point attributes off that data structure? the DOPNET OBJNAME Geometry attribute syntax doesnt fit together like a sop path…
Anyway, I am making progress, but slower than id hoped for. I need more variety in the shipped examples as they usually beat on the same paths .
- 512 posts
- oblongowl
- 40 posts
- oblongowl
- 40 posts
- 512 posts
- oblongowl
- 40 posts
