Hi everyone,
I downloaded the last version of houdini, 12.0.581, and when I try to launch the program, the houdini license administrator appear, so I check the ‘install my free Houdini apprentice licence but after that when I click on ’ run ‘ it’s the same window appear one more time, at the end I can't start houdini actually. Also if I click on the ‘ view licences ’ all licences are ok, into the installed licenses also the server information.
Some clue ? .
Cheers
[MAC] Apprentice licence probleme
2660 4 2- nikoDan
- 18 posts
- eitht
- 257 posts
- nikoDan
- 18 posts
- rafal
- 1450 posts
it could be related to the local licensing and file write pemrissions or something similar. See if any of these FAQs help:
http://www.sidefx.com/index.php?option=com_content&task=view&id=1039&Itemid=273 [sidefx.com]
- nikoDan
- 18 posts
I changed the write permission on this file, licences.local, by a chmod command, it was -rw-rw-r– and now it's -rwxrwxrwx, but it still doesn't work.
I tried an another way, into a shell I made an mv command on this file /Library/Preferences/sesi/licenses.local to /Library/Preferences/sesi/licenses.local.old, after that I had re-start my houdini and the license installation appear again, but this time when the installation of licenses was done, and I clicked on Run, houdini was started perfectly. I don't know why the licenses was be corrupted but it re write another “fresh” license. I hope my problem will help someone else.
Regards
Regards
