I am working on a simple FLIP sim. When I simulate with Particle Separation set to 0.1 (11k particles at the start), it caches all 500 frames without any problems. However, when I lower the Particle Separation to anything lower, Houdini gets hung at some point. With Particle Separation set to 0.05 (88k particles), Houdini hung at frame 23 and with 0.02 (1.4m particles) it got hung at frame 19.
The scene doesn't really contain anything special, just a few static geos for collision. Any idea what could be causing the issue?
This is on a Quad Core machine with 8G of RAM.
High Res Flip Sim - H12 hangs while caching
6575 15 2- naeem151287
- 18 posts
- circusmonkey
- 2624 posts
- naeem151287
- 18 posts
- circusmonkey
- 2624 posts
- eitht
- 257 posts
- naeem151287
- 18 posts
circusmonkey
Your post mentions nothing about writing to disk using the ROP output driver. I am rendering and writing to disk high res FLIP fluid sims as I write this with no problems at all. Using H12.0.586 & 48 gigs of ram & X 2 xeon 2.4GHz 6 core processors.
rob
Yea sorry I forgot to mention that. Any ideas what could be causing the problem with my sim?
P.S. : Tried using HBATCH and render and the process still got stuck.
- pbowmar
- 7035 posts
Is the process getting stuck, or are you running out of memory?
Run “top” in a shell (or if you're on Windows, do Ctrl+Shift+Esc to run the process monitor) and watch as you're running the simulation. If the Houdini process gets to within 10% of your physical RAM then you're likely running out of RAM and the machine is in swap. It's not actually stuck, it just means you need more RAM
PEter B
PEter B
- naeem151287
- 18 posts
Hi Peter,
The TOP info at the point the sim get's stuck -
top - 19:34:07 up 2 days, 1:12, 1 user, load average: 2.28, 2.24, 1.84
Tasks: 231 total, 2 running, 229 sleeping, 0 stopped, 0 zombie
Cpu(s): 25.0%us, 0.2%sy, 0.0%ni, 72.3%id, 0.0%wa, 2.6%hi, 0.0%si, 0.0%st
Mem: 8178492k total, 7380152k used, 798340k free, 73236k buffers
Swap: 1952760k total, 387088k used, 1565672k free, 4900028k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2716 i7959201 20 0 2766m 1.3g 72m R 100 16.3 45:18.27 houdini-bin
I am not sure about running out of memory because I believe I should be able to simulate more than 10k particles without running out of memory, especially since I am not caching to memory but to disk. Do you think there is something wrong with my file?
- pbowmar
- 7035 posts
- naeem151287
- 18 posts
- pbowmar
- 7035 posts
- naeem151287
- 18 posts
- pbowmar
- 7035 posts
- naeem151287
- 18 posts
- naeem151287
- 18 posts
- naeem151287
- 18 posts
