Can't figure out Voronoifracture create output group problem
6844 7 0- MPiland
- 16 posts
So, I'm following the smashing columns tutorial and I'm at the part where I'm assigning materials. In the circle_object1 network, there's a node called “file” and it says to attach a material node to it. So I do. Then it says in that node paramters, to type “inside” in the group field. Well that seems to not work for my scene. When I click the down arrow next to the field, nothing comes up but in the video he has a long list of items. Is there something I'm missing? I've attached my HIP file. I'm using Houdini 12 BTW. Thanks!
Edited by - June 7, 2012 23:00:15
- sadhu
- 112 posts
- MPiland
- 16 posts
- sadhu
- 112 posts
- MPiland
- 16 posts
- sadhu
- 112 posts
- MPiland
- 16 posts
- MPiland
- 16 posts
Actually, looking at this again and trying again, this isn't an option in the “fracture_SOP_solver” node…at least not when highlighted. Is there anything else I'm missing? I'm uploading the HIP file again because I redid the tutorial just to make sure I'm not missing anything. I even went further to the “voronoifracture” node and and in the “Groups” param checked the “Create Output Groups” box. Do I need to re render the bgeo file?
EDIT: Ignore…figured it. I just needed to move the slider along…it was giving me a warning saying that there were no groups, but it's because it hadn't been shattered yet. ops:
