I am getting some empty voxels when I specify octree divisions. I can get up to 256 divisions with minimal artifacts, but at that point it seems better to just use 1 division and do the whole volume. This volume I have is a very thin shell that will be the atmosphere of a planet.
Jason
Edit: I have specified explicit bounds as well.
Rendering artifacts with Volume procedural octree divisions
3394 2 1- stronglikebool
- 28 posts
- davedjohnson
- 221 posts
I got the exact same thing. I'm trying to do a planet atmosphere also.
Support said:
I'm working on doing this with OpenVDB volumes instead.
Support said:
Increasing the octree divisions larger than 1 is error-prone - I've just updated the help for this parameter to the following to clarify the issue:
Octree Divisions:
Specifies the number of divisions to use in constructing an
acceleration data structure for the volume. The default of 1 division
will cause the renderer to generate samples within the entire bounding
box for the volume. Larger values will trigger a preprocessing phase
before rendering that will evaluate the VEX function on a uniform grid
to try to determine the important parts of the volume, so that empty
portions of the image will render much faster. Note that values larger
than 1 will only produce a correct result if the feature size in your
volume is larger than the division size - otherwise the preprocessing
phase will miss small details in the volume which will then fail to
appear in the render, so increasing the octree divisions is not
recommended.
The step size for a quality of 1 is set to 1/100th of the maximum box dimension. The quality is then a scale factor applied to this step size, so quality of 2 will give you a step of 1/200th of the box dimension.
- jpparkeramnh
- 178 posts
