I'm wondering since few weeks how to transfer viscosity attribute between 2 different object.
This is my file, I would like that my main water fluid (in blue) change the viscosity of my box (to create a water effect against a box of sand by example). In order to change my viscosity of 100000 to 100.
Thank you in advance for your help
FlipFluid transfer Viscosity
5076 4 1- sliverfx
- 22 posts
- Solitude
- 373 posts
- sliverfx
- 22 posts
wow thank you so much Ian ! It's perfect, your method is fast.
I'm wondering something about water and sand “Group” if I desactivate both the setup continue to work perfectly.
Was it just a test before the final solution ?
Is it possible to explain to me quickly how work “blast1” and “blast2” ?
Thanks a lot.
Thanks a lot.
- Solitude
- 373 posts
Yeah, I was going to put them in separate groups to separate them, but I ended up using viscosity instead. The one blast node has something like @viscosity>1 this tests for the point attribute on each point, and filters our the points for the blast node. The other one references this, but keeps the opposite set of particles… essentially giving you water and sand.
Ian Farnsworth
- sliverfx
- 22 posts
