hi everyone ,
i was working on a long session with H13.0.251 .
everything stable and fast .. i was in a good mood too ..
then .. something or somewaht mentioning “ Pools , Events , Queue & Co ” ( ! )
i have meet that before too . so , i saved the scene .
tried to reopen Houdini but failed . tried restarting my pc and latter Hou again .. and again failed .
anyone has had a similar experience and resolved it ?? ( Win 7 x64 )
any suggestion is appreciated since time is pretty precious these days for me ..
!thanks
! Crash on starting H13 ( Win7 - H13_build251 ) [ SOLVED ]
4086 3 0- zarti
- 330 posts
- zarti
- 330 posts
- halfdan
- 599 posts
- zarti
- 330 posts
halfdandisplay.pref in cooperation with display_options.pref.zartiAnd what was it?
i found the culprit !
yesterday , i started to hunt for the file .
deleted one .. started Hou .. crash !
deleted another one .. started Hou .. crash !
.. and so arrived at display_options.pref .
once i deleted it , i had access to Hou .
in order to give you a more detailed reply , today i continued few other tests .
i noticed that deleting display.pref and left display_options.pref , Hou starts fine .
when both ( mentioned above ) old config files are being read by Hou , i get crash .
( you'll find those attached )
test i did today was done in build_260
i know my situation is hard to reproduce , ( described in 1st post ) but i hope to see this thing fixed , since it simply has to do with display configuration files .
till then , hope my solution wd spare time , nerves and full config_dir's back-up and restore procedure to someone in future , which might be even useless as in my case .
– thank you for showing interest halfdan !
.cheers
except the things that cannot be seen , nothing is like it seems .
