I already e-mailed support, my work is brutally interrupted by that.
I followed every instructions on the documentation, including returning my license and retrieving it , only to get the same Houdini error :
License Error: Unable to connect to hserver for license acquisition
Please help me,and warn people that are upgrading OS X on there Mac Pros too.I didn't see it coming!
Urgent ! Help! Yosemite OS X deleted my Houdini Indie licens
13935 20 1- emihich
- 25 posts
- edward
- 7760 posts
- emihich
- 25 posts
- edward
- 7760 posts
Probably not.
Looks like you found a solution on the other thread though. Referencing it here for completeness.
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=33938&highlight= [sidefx.com]
- Arkahtek Musicfilm
- 69 posts
- anon_user_37409885
- 4189 posts
Launching Houdini from the terminal should make mPlay work. If you launch Houdini from the Finder icon mPlay won't work, currently!
Please see more details in this thread:
- 69 posts
- 4189 posts
- tinyparticle
- 175 posts
- emihich
- 25 posts
thank you for helping.
I've apreciated that.
Just comparing experiences though :
I also turned off my computer and found my license broken again
when restarted my Mac Pro.
nevertheless , i've received an e-mail from support and typed Hindie at the terminal.
In the begginning could not render anything using mplay, but
with the variables relaunched now , everything seems normal .
Still think this should be adressed on a new version of Houdini 13#.
:shock:
:shock:
- 69 posts
Same as the poster above..it worked once for me after upgrading OS X ..I couldn't connect to the server after some research I see I have 2 server names or something like that, one has a .home extension the other has .local extension I have to versions I updated houdini to 13.547 it is also asking me to update my server to 13.547 which is currently running on my Mac (new to all this stuff so forgive me) how do I do that? Houdini still runs from terminal just fine just no Mplay. Didn't have anyof these problems before upgrading to yosemite
- 69 posts
I meant to say..once I take my computer off after use ..and I start it again Mplay stopped rendering. It rendered once after the OS X update..after I found out here I had to launch houdini from the terminal or else I would get cannot connect to hserver license or something close. I tried typing hindie ..but now it's asking to update my server to 13.547
- 69 posts
ok so i got mantra to render, but now my previously saved hip files originally saved on mavericks is not rendering thru mantra. only new projects i started on OS X Yosemite. i ran hserver in the Houdini terminal to get mantra to work on OS X Yosemite. Any body know how to get my previously saved hip files to render in mantra on OS X Yosemite?
- 4189 posts
- 69 posts
- 4189 posts
- 69 posts
- 69 posts
- emihich
- 25 posts
Everything seems to work fine now , but I have
to start Houdini Indie using the shell terminal utility
everytime.
Thank you for the precious support.
How can I get the update that adresses Yosemite compability and use the
default initialization ?
Feels weird to use the Shell terminal, because of a bug, right ?
In other words , How can I have normal functionality with a new Houdini version , compatible with Yosemite again ?
in Time : Houdini Indie is the Greatest gift to independent artists ever,
afordable sophistication !Thank you Side FX.
everytime.
- 4189 posts
