Hey,
I am working through tutorials but always when i try to use the rop geo + file node. It will only show me the end state of the animation.
I tried a lot of options but nothing seems to change it.
Someone may know a solution to this?
Rop Geo + File not saving animation
1753 4 0- Andreas Oehmig
- 6 posts
- Andreas Oehmig
- 6 posts
- mfrancos
- 1 posts
- Andreas Oehmig
- 6 posts
- Sugleris
- 30 posts
Yea as the poster said above your missing your frame variable, so you wanna put in. “render_layer_name.$F.bgeo”
If you make it $F2 or $F3 or $F4 you will increase the padding. Hence, with $F4 youd get :
"render_layer_name.0001.bgeo
etc.
I sometimes use ROP's with $OS.$F4.bgeo which will reference the name of the actual operator ( in this case whatever you name your ROP output) into the filename.
Cheers!
etc.
Cheers!
Shortcuts are supposed to be hard, if they were easy then they would just be “The Way”.
