Hey guys
Just have a vdb question here, is possible to produce vdb by partition? ya, well, i know, houdini should be able to do it, but any idea how to do it? for example i have a box, and i want to convert that into vdb, but, i don't want to do that by vdbfrompolygons, to get vdb in one go, instead, i want to produce that box vdb in 4 or 5 section(partition). and after that, merge them together.
Anybody has idea how to do it? any answer would be much appreciate!
thanks in advance
partition vdb generation
2942 6 1- nran
- 36 posts
- mosssi
- 51 posts
That's really the same procedure. you can make a name attribute for your different partitions and with apolycap and a vdbfrompolygan in a foreach loop merge the differret vdbs or manually by using a blast node then converting then merging.
2 x Xeon E5-2670 - 64 GB DDR3 RAM - Nvidia GTX 960 - Win 10 64x
- nran
- 36 posts
mosssi
thanks for the relpay, yes, i can do that, i can make some groups, convert into vdb and then merge together. but, in the real situation, if you have a lots of geo, we can't do that manual approach.
another other way to do it?
- mosssi
- 51 posts
- nran
- 36 posts
- mosssi
- 51 posts
- nran
- 36 posts
