How to pass object level inputs into geometry level?
   5244   2   1
Hi. I have a little problem. Im trying to create an HDA but im stuck with inputs. One of my inputs is a curve, which should be used by multiple geometry nodes. The problem is that my input is on the obj level but I need to use it on geometry level. Thanks in advance
I think you want to use either a file sop or object merge sop , depending on what your doing
Rob
Gone fishing
Inputs in /obj are for parenting and transforms.
So if you wire something into your object level HDA, you are simply parenting it and not passing any geometry data.
I don't know what your HDA is supposed to do, but it sounds like it's better suited as a SOP asset…
